flywheel material and type >
Old 07-25-2016 | 11:57 AM
Default flywheel material and type
I am putting together a 540 engine that has an internal balance crank and rotating assembly. I have to buy a 168 tooth neutral balance fly wheel. Can I use a aftermarket automotive manual transmission flywheel? what material is better cast,steel, billet steel? Will bravo drive coupler bolt up on automotive flywheel? I have a neutral flywheel but its for TRS setup.Starter ring gear on wrong side. Thanks for any info.
TwoKs is offline
Old 07-25-2016 | 12:34 PM
I bought some real nice billet units from Teague (if I remember right) Balance was less that 1/2 a gram
TAStevens is offline
Old 07-25-2016 | 04:53 PM
GPM
Summit or Jeg's would have either.
GPM is offline
Old 07-25-2016 | 05:47 PM
Thanks for info guy's. Just ordered one from Teague. I guess I will list the TRS one on swap/sell fourm
TwoKs is offline
Old 07-25-2016 | 05:51 PM
the bravo coupler uses the same blot pattern as a gm 11 inch clutch so yes you can use a automotive flywheel.
mike tkach is offline
Old 07-25-2016 | 05:57 PM
vintage chromoly's Avatar
Bought an SFI RAM flywheel from summit for around 200 bucks. Steel
Made in USA!
vintage chromoly is offline
Old 07-25-2016 | 09:52 PM
I've seen some of those flywheels that were made for the ring gear to be able to go on both sides... not the case on yours? The Teague piece looks nice.
Faster7 is offline
Old 07-26-2016 | 06:10 PM
I was hoping I could but not enough to back up ring gear after machining.The wheel I have looks like a Teague also
TwoKs is offline
Old 07-26-2016 | 06:12 PM
Thanks for info Mike
TwoKs is offline
Old 07-29-2016 | 07:26 PM
Got my flywheel today from Teague. Nice
TwoKs is offline
