525 with whipple's
Old 07-27-2016 | 12:21 PM
Default 525 with whipple's
Going to look at a boat with 525's with whipple's. Looking for some input good set up or bad ?
riverboater is offline
Old 07-27-2016 | 02:16 PM
VoodooRob's Avatar
Hours are important when the Whipples were installed and what was done to the engines for a re-fresh or not at time of install. Definitely find out the drive maintenance and rebuild history.
VoodooRob is offline
Old 07-27-2016 | 06:20 PM
240 total on all
Old 07-27-2016 | 07:44 PM
Top end rebuilds if they haven't already at a minimum. If the boat is a 35'+ and anything bravo they might need attention too.
1MOSES1 is offline
Old 07-28-2016 | 05:18 AM
I've got that set up with 150 hours. Zero problems thus far. Absolutely bullet proof for me. As mentioned above, at 250 hours you will need the value springs done and the bigger concern with this package will be the drives, assuming the boat has Bravos.
First set lasted two seasons, I'm into my third season now and they're still holding together.
Apexwarrior is offline
Old 07-28-2016 | 06:34 AM
F-2 Speedy's Avatar
Just remember, those aren't blower pistons..........a buddy of mine had 3.3 whip's on his stock 525's and when pulled apart there were five cracked pistons, good luck
F-2 Speedy is offline
Old 07-28-2016 | 06:46 AM
Drives are Xr's
Old 07-29-2016 | 09:00 PM
who tuned it?
sutphen 30 is offline
Old 08-02-2016 | 09:20 AM
riverboater,i see you are from channahan,do you boat on the illinois/kankakee rivers?i keep my cruiser at the big basin marina.
mike tkach is offline
Old 08-02-2016 | 09:45 AM
F-2 Speedy's Avatar
Originally Posted by sutphen 30
who tuned it?
Dustin Whipple
