Need Ignition Switch Help - Fountain >
Old 08-01-2016 | 07:03 PM
Default Need Ignition Switch Help - Fountain
I need a new ignition switch. Has anyone replaced one that can provide a part number?
I went to start 1 of my engines and the key spun 360* in the switch. I managed to get it started, but it needs to be replaced.
I've searched online, but don't see any that are the same. This is a 2002 Fountain Lightning. Thanks for any help that anyone can provide.
Here is a pic of the back side.
ALL_IN! is offline
Old 08-01-2016 | 07:06 PM
Looks like a common switch. Should be able to get one at any auto parts or boat store.
picklenjim is offline
Old 08-01-2016 | 09:05 PM
That's what I thought, but there seems to be two different sizes. 13/16" and 7/8" hole size. My panel doesn't seem to be either of those. Am I just being a moron?? LOL it's also not a round hole.
ALL_IN! is offline
Old 08-01-2016 | 09:42 PM
Do a search for Universal Ignition Switches. Tons of them on ebay that are made with the flat sides. How big is the hole for yours?
Old 08-02-2016 | 01:58 AM
Call Livorsi Marine, ask for Mike or Fredd..847-752-2700
Bawana is offline
Old 08-03-2016 | 06:02 PM
Did the whole switch spin? Those are notorious for coming loose. Usually you have to get the backing nut just right, use a rag with channel locks on the front.
Katanna is offline
Old 08-04-2016 | 12:37 PM
No, the insides spun around in the housing - I'd guess the spring or detent on the inside broke. Key would just turn all the way around. I ended up ordering Sierra MP41030 Switch. Ir arrives today, so I'll know pretty quickly if I can boat this weekend or not.
I couldn't find any that indicated flats on both sides - but maybe my search terms weren't correct. Most did not indicate flats at all for that matter.
ALL_IN! is offline
Old 08-05-2016 | 07:36 AM
Happy to say that the Sierra MP41030 Switch fit properly on an '02 Fountain Lightning. It does have the double D shaft - he77 maybe they all do?.
I'm back in business !
ALL_IN! is offline
Old 08-08-2016 | 10:37 PM
Good Deal
253 is offline
