Blind mounting swim ladder? - 89 Baja 226 Islander >
Old 08-13-2016 | 09:29 PM
Question Blind mounting swim ladder? - 89 Baja 226 Islander
Hi,
First post
I recently purchased an 89 Baja 226 Islander 226 open bow and I would like to mount a swim ladder under the integrated swim platform. I do not see any viable way to back up mounting hardware, as it does not appear I can access the ~6" deep cavity between the top of the platform and the bottom. i have seen others with this model with a swim ladder via online photos when researching, but I cannot tell how they are mounted. From research (and common sense) I am assuming all types of screws cannot be used, but I did find a product called blind fasteners, but I don't know how well I would be able to seal the installation to prevent water intrusion. I am a rookie, so am I missing something? Any suggestions or advice would be greatly appreciated.
Thank you,
Joseph
ProblemSolved89 is offline
Old 08-14-2016 | 07:49 AM
I installed a aquastep ladder under my Fountain a few years ago and it came with all the hardware. If you use a 3M marine sealant and do what they call a wet installation of the hardware you should be fine.
fordf350 is offline
Old 08-14-2016 | 09:14 AM
Originally Posted by ProblemSolved89
Hi,
First post
Thank you,
Joseph
I'm in the same boat as you. Baja 302 with loose swim ladder fasteners up in the inaccessible platform. Hope someone has a trick!
Tractionless is offline
Old 08-14-2016 | 06:11 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
https://www.amazon.com/gp/aw/d/B0000...=1&pc_redir=T1
These Garelick fasteners/bolts have been discussed on here for mounting bolsters and heads. I think this could work for you guys. They are available in stainless steel.
Sydwayz is offline
Old 08-15-2016 | 01:58 AM
Thanks, may be worth a try.
Old 08-15-2016 | 08:45 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Was on my phone yesterday. Here are some previous threads now that I can find them easier:
http://www.offshoreonly.com/forums/f...s-how-fix.html
http://www.offshoreonly.com/forums/f...rew-holes.html
Sydwayz is offline
Old 08-15-2016 | 08:40 PM
Default Thanks
Thanks Sydwayz. I have ordered the toggles and I think they will work very well.
Joseph
