drive swap alpha 1 gen 2 to bravo one >
Old 08-14-2016 | 12:59 PM
Default drive swap alpha 1 gen 2 to bravo one
what would i need to go from a alpha to bravo 1 its on a baja hot shot i swapped out the 4.3 to a 5.7 the alpha had a 1.8 ratio i figure i would be better off buying a used bravo 1.5 than changing the gears in my alpha
mira boater is offline
Old 08-14-2016 | 08:38 PM
Find a used alpha and bolt it on. You have to change the transom assemblies and setup the engine for a bravo style impeller pump. Lots of time and money involved unless you plan on going with big block power later on its not worth it, in my opinion.
87MagnumII is offline
Old 08-14-2016 | 08:55 PM
SB
Stay with an Alfalfa.
SB is offline
Old 08-14-2016 | 09:15 PM
350 keep the alpha. Used alphas are everywhere.
Crude Intentions is offline
Old 08-14-2016 | 09:19 PM
SB
Yup. And new Aftermarket complete drives,uppers, and lowers are relatively cheap.
SB is offline
Old 08-14-2016 | 10:13 PM
Rookie's Avatar
Yup, maybe they will come out with a Bravo upper soon.
http://www.sterndrive.cc/Mercruiser-Sterndrive.html
Rookie is offline
Old 08-15-2016 | 10:13 AM
Thanks for the help I will look for an alpha with a 1.5 ratio
Old 08-15-2016 | 02:06 PM
Also, the gear change is done in the upper so that is all you need if you find one. The SEI one is 750$ new.
Mr Maine is offline
