A little more Tinkering >
Old 08-20-2016 | 07:53 AM
Tinkerer's Avatar
Default A little more Tinkering
My drive is mounted QUITE high. At top speed I am loosing water pressure. SO I welded up the original water intake at the nose of the IMCO -3 shortie. Then I cut a new slot about 3 inches back ( that is as far as I could cut it.
Hopefully this solves the problem or else I may have to install a scoop. I don't want to install a through hull pick up If I don't have to.
[ATTACH=CONFIG]558494[/ATTACH]
[ATTACH=CONFIG]558495[/ATTACH]
Attached Thumbnails A little more Tinkering-img_20160818_215247847.jpg   A little more Tinkering-img_20160819_214216005.jpg
Tinkerer is offline
Old 08-20-2016 | 09:18 AM
why not just use offshore pick up
sutphen 30 is offline
Old 08-20-2016 | 01:19 PM
Tinkerer's Avatar
Why make more holes in the hull for water to leak in if I can get this to work. Plus the through hull pick up will cause more drag. Believe me I will get this to work. The boat is going 112 MPH and I feel it will hit upper teens once I get the prop right and trim right. This boat has less than 4% slip.
Tinkerer is offline
Old 08-20-2016 | 03:21 PM
That's smoking bro. How's it feel in the teens? Lose any hats or sunglasses yet.
getrdunn is offline
Old 08-20-2016 | 03:23 PM
If you did end up having to go through the hull you'll prolly want to go no more than 6" from the transom. Lol. Sounds and looks like your on the right track though. Good work.
getrdunn is offline
Old 08-20-2016 | 05:00 PM
Tinkerer's Avatar
Wife lost a hat at 95
112 was real smooth.
I need to try out the labbed Bravo 30. I lost the seawater pump last Sunday and had to pull the boat out.
I have to learn all over how to drive this boat. How much trim at what speed.
Learning all about speed and cornering.
Tinkerer is offline
Old 08-20-2016 | 05:34 PM
I can only imagine. Not exactly a boat you'd wanna put a newbie behind the helm of. Even with years of experience you still gotta take one day at a time. Pushing the limits is what it's all about however doing it with respect of the boat and the water is obviously key. And of course others in the boat being #1.
Regardless sounds like a riot a whole new exciting experience.
getrdunn is offline
Old 08-20-2016 | 05:54 PM
Tinkerer's Avatar
Last Sunday was by myself.
Tinkerer is offline
Old 08-20-2016 | 09:01 PM
Have you tried a 5 blade yet? I broke a Bravo 4 blade a couple weeks ago and my mechanic put a pair of 5 blades on it for testing. No numbers to share but really changed how the cat handled. I noticed anothe 30' that was for sale running 130 mph was also running 5 blade Maximus
papps is offline
Old 08-20-2016 | 10:02 PM
Tinkerer's Avatar
Your Daytona is a twin engine = heavy stern. The 26 Daytona has a center of gravity that is too far forward. With a Maximus 5 blade prop I get way too much transom lift. It literally rides on the prop and the front sponsons. I was at full throttle with the stock Maxomus and when I let off the throttle it felt as if I had slammed on the brakes. I was running on the bow. I am going to have the Maximus 28 labbed to lessen the transom lift and use it when I have a heavy load.
Tinkerer is offline
