whats the torq spec for bravo transom plate? >
Old 08-20-2016 | 01:51 PM
jeff32's Avatar
Default whats the torq spec for bravo transom plate?
for the 1/2 inch nut on the internal transom plate?
jeff32 is offline
Old 08-20-2016 | 02:58 PM
The 8 locknuts are torqued to 25 lb-ft using an X pattern starting from the middle. The manual I have says to tighten in small increments and go around several times before the proper torque is applied.
floatingphil is offline
Old 08-20-2016 | 06:26 PM
jeff32's Avatar
25 is not a lot!!!
thanks for the info!
jeff32 is offline
Old 08-21-2016 | 04:45 PM
you are right. it is not a lot. they are strong stainless studs. except the aluminum lower one on the early bravos. you could easily go 75 to 90 ft lbs. if you were trying to seal compression in you would need that much torque. if you don't want to crush your wood transom, you need around 25 ft lbs.
dereknkathy is offline
