Power steering pump fitting Aeroquip? >
Old 08-20-2016 | 05:03 PM
Rookie's Avatar
Default Power steering pump fitting Aeroquip?
Where can I get this fitting on the back of the pump? I was going over the fittings on my new project and I don't believe this to be safe.
Rookie is offline
Old 08-20-2016 | 08:13 PM
c_deezy's Avatar
Alternative (albeit $$$$) option:
http://www.cpperformance.com/p-11506...o-fitting.aspx
c_deezy is offline
Old 08-20-2016 | 08:51 PM
rookie,i believe that is from latham marine.it uses a high pressure hose good to 3000 lbs if i remember correctly.
mike tkach is offline
Old 08-20-2016 | 09:36 PM
http://www.speedwaymotors.com/Steel-...-GM,37128.html
This is what I used, not sure why CP is saying they are 5/8 threads mine were 16mm.
Looks like if its a old pump then they us 5/8
https://www.summitracing.com/parts/tff-5553a
Here is one from summit for 15 bucks
Any good hydraulic shop can make you up a hose, I usally use NAPA.
turbom700 is offline
Old 08-22-2016 | 10:48 AM
Rookie's Avatar
TTT
Thanks for the responses, but I'm looking for the actual fitting, not an adapter end.
Rookie is offline
Old 08-23-2016 | 04:25 PM
Originally Posted by Rookie
TTT
LATHAM MARINE.they will have the exact fitting.
Old 08-23-2016 | 04:30 PM
I'd just run it. Looks fine.
MILD THUNDER is offline
Old 08-27-2016 | 07:28 PM
Rookie's Avatar
Update,
Local hydraulic shop that carries Aeroquip had the reusable fitting in -6 so I just cut and crimped a -6 to an old steering line that I had laying around. Approximately $15 for the repair.
Thanks everyone.
Rookie is offline
Old 08-29-2016 | 06:47 PM
That looks so nice maybe you should change out the other fitting :-)
BenPerfected is offline
