Water in oil. >
Water in oil.
Water in oil.
Old 09-01-2016 | 07:30 AM
Default Water in oil.
Hi guys. My boat is finally dialed in, so I am trying to help a friend. He has a 468 with Gil's. The boat runs great, but when he shuts it off... Couple hours later... He has water in oil. Any ideas? I was thinking exhaust issue. The boat can run all day and not mix, shut it off.... Screwed.
monster12valve is offline
Old 09-01-2016 | 08:10 AM
maybe a bad oil cooler.
mike tkach is offline
Old 09-01-2016 | 08:14 AM
Thank you for the reply, is there a way to test it?
Old 09-01-2016 | 08:58 AM
yes,remove it and pressure test the water side.
Old 09-01-2016 | 10:19 AM
How much pressure,20-25psi.????????
30ftpanther is offline
Old 09-01-2016 | 11:16 AM
If the oil cooler is leaking you normally loose oil into the water system. Oil is 60 psi and water is only 15 or so psi.
kvogt is offline
Old 09-01-2016 | 11:55 AM
Does he have the turbulaters installed btwn the risers and manifolds. Also what kind of cam is he running?
getrdunn is offline
Old 09-01-2016 | 12:39 PM
So while it's running the oil would be pressing out into the water, but if it's leaking bad enough than water can drain back into the oil when it's under no pressure, right? I'm asking for myself as well.
Baja Rooster is offline
Old 09-01-2016 | 12:53 PM
Not sure about the turbulater... I will check. He is running a pretty good size cam, I will get actual specs from him later this evening.
Old 09-01-2016 | 01:07 PM
If it is leaking bad enough you run out of oil quickly.
kvogt is offline
