#6 drive
Old 09-20-2016 | 06:00 PM
Zero Patience's Avatar
Default #6 drive
What a pain in the ass #6s are to put back on. #%#}{||}#}, getting ready for Key West and had the seals replaced. 5 minutes to take off 1 hour to reinstall😩
Zero Patience is offline
Old 09-20-2016 | 07:51 PM
It helps to trim slightly negative, bottom of tilt housing flush or just slightly in from the gimbal ring, positive trim makes it very difficult. Turn input shaft so the shaft crosses are vertical, hand over the top with drive low enough to put your hand over the top, the u-joint closest to the drive may almost be dragging in the tilt housing. Use fingers on top of cross to tip shaft until it will start in tube. When you feel it is in the tube, remove your hand, check with a flashlight if unsure. Rotate the propshaft while "gently" pushing in and lifting the drive to center, not high. If it is an nxt or other mechanical transmission, it helps to have it in gear to keep the transmission shaft from rotating, a little more "feel" with hydraulic unless it is a driveline so someone can hold the driveshaft from turning. With some experience it will seem much easier, although once in a while it seems like one will be a little more difficult. If so, I usually find I should step back and try again without being frustrated, it seems like then it will fall right in place!
Falcon is offline
Old 09-20-2016 | 08:31 PM
mmb
Quit whining. Drink some more Rum!!
mmb is offline
Old 09-20-2016 | 08:58 PM
From: East Texas Waterfront- running errands if anyone asks
I would go with what Falcon said, and then the rum thingy.
Flightplan is offline
Old 09-21-2016 | 07:38 AM
Quinlan's Avatar
AND your going to KW More then I can say lol
Quinlan is offline
Old 09-21-2016 | 09:41 AM
Sydwayz's Avatar
Forum Regulator
Originally Posted by Zero Patience
What a pain in the ass #6s are to put back on. #%#}{||}#}, getting ready for Key West and had the seals replaced. 5 minutes to take off 1 hour to reinstall��
I'll gladly trade you for a set of Bravos, and take those nasty things off your hands. Can you fill the transom cutout with 5200 and call it good?
Sydwayz is offline
Old 09-21-2016 | 11:10 AM
HUSTLEthis's Avatar
We put the little red shop rags in the u-joints to hold it straight....then pull them out as it starts in....
On a side note...You are only putting back on the drives....I just pulled an engine to rebuild before KW.... See you there!
HUSTLEthis is offline
Old 09-21-2016 | 11:29 AM
mmb
We will be there also! Thankfully we only have an interior panel to repair before we go!!
mmb is offline
Old 09-22-2016 | 08:16 AM
Sydwayz's Avatar
Forum Regulator
Some time back, there was a discussion about someone who had SSM VI drives on boxes, and the joke was it would be easiest to suspend the boat from a 50' crane, and insert the drives from above with the shafts pointing straight.
Sydwayz is offline
