5/8 Fuel Pick Up
Old 09-23-2016 | 11:18 PM
BUP
Default 5/8 Fuel Pick Up
I can not remember the company that I order 5 /8 inch fuel pick ups to install in the fuel tanks as it was a couple of years ago. Also last year I ordered 1/2 inch fuel pick ups from another company and can not find the invoice to call them asking if they have 5/8 as well. Anyone know who has these and I will need to cut to length most likely also just an FYI will be using # 10 AN fuel line connections to the pick up. Thanks for the help.
BUP is offline
Old 09-23-2016 | 11:27 PM
Wobble's Avatar
SORE MEMBER
Seems like that is something you could weld up or have welded up, just need a fitting and some tube
Wobble is offline
Old 09-24-2016 | 02:18 PM
I had a lot of trouble finding one until I googled diesel fuel marine pick up. Don't remember where I eventually found it.
tmmii is offline
Old 09-24-2016 | 02:55 PM
F-2 Speedy's Avatar
Try a company out of edgewater Fl called Centroid Products. .Tel # 386-423-3574
F-2 Speedy is offline
Old 09-25-2016 | 08:10 AM
Roger 1's Avatar
If you are going to weld them in the tank, I' sure that a section of aluminum tube, or pipe if you want threads on one end, would work just fine. I'm pretty sure that whomever is up to the task of properly welding them to the tank would find it to be no problem making them.
Roger 1 is offline
Old 09-25-2016 | 08:31 AM
Suggest Florida Marine Tank in Henderson NC
AllDodge is offline
