classic 22 depth sounder ??
Ok, I want to ad a depth sounder to my 2007 classic 22 . I would like to go shoot through hull. as apposed to a transom mounted transducer or a through hull mount . I'm not sure if the hull construction will allow a shoot through set up. Is there anybody that has this setup on a C-22 ? What make /model depth sounder are you using ? What is the location of the puck ? What did you use to mount the transducer puck.Finally are you happy with the readout accuracy at different speeds ? Any first hand info on this application would be greatly appreciated. thanks .
From what I've read: Just because the hull construction will allow scanning through doesn't mean there isn't an air bubble present in your location of choice which will interrupt the readings. The same is true if not epoxied correctly. I went transom mounted in my 20 yr. old boat to avoid such issues.
Thanks again guys. This the kind of info I was looking for. I know you can also bed the puck in petroleum jelly for testing purposes and move it until your hearts content . Final epoxy once happy with a location. I just needed to know it was doable before ordering a shoot through transducer.
