500 EFI compression
Old 09-26-2016 | 05:10 PM
Default 500 EFI compression
Looking for some opinions please. Found a beautiful boat for sale with a 2001 500efi. 338 hrs, springs done at 300 hrs. Compression done 165 high, one cylinder was 145 and one 135. Is that range to much? Was told there is probably a problem. What should the numbers be? Thanks for any info
toyboat991 is offline
Old 09-26-2016 | 05:20 PM
onesickpantera's Avatar
I like them to be within 10% of the highest number. Did you try squirting a little oil in the low cylinder to see if it cam up?
onesickpantera is offline
Old 09-26-2016 | 05:23 PM
jeff32's Avatar
I will test mines in the next couple weeks also, curious to see what my readings will be!!!
jeff32 is offline
Old 09-26-2016 | 06:57 PM
No didn't squirt any oil, but checked cold and then again hot.
Old 09-29-2016 | 05:41 AM
you can put rings and rod bearings and lap the valves in a tired old engine and get good compression readings across the board. there are guys on here who won't buy a boat with the engine in it. unless the engine comes with paperwork and a warranty, you pretty much gotta consider it little better than a rebuildable core. and an engine is easier to fix than a hull or stringers or interior, etc. if the boat is better than the other choices you have in your price range... I am not saying buy it anyway, but you can usually get the price down a bit more too.
dereknkathy is offline
Old 09-30-2016 | 03:35 PM
Solid , Solid advice !
HALLETT FAN is offline
Old 09-30-2016 | 03:56 PM
When I was looking to buy I wanted a boat that had motors that where unopened for the reason above. My 500efi's had 345 on them and where never opened and to me that was a good thing. The winter after I got it it went in to get top ends and a good go through that way I knew it was done right by the guy I wanted to do it. Now I don't second gess the work that was done or sead to be done. Just my opinion
1989mach1 is offline
Old 09-30-2016 | 04:02 PM
Befor the the rebuilds my port was 155 to 160 lbs and stb was 140 to 155 leakd own was 5 to 15%
Old 10-01-2016 | 10:43 AM
if a cylinder is 10% or more down their is a problem,it is usually caused from poor sealing at valve&seat.this is very common on the hp500 engines.
mike tkach is offline
Old 10-01-2016 | 12:24 PM
agreed, valves not seating, may be starting to tulip a bit
ezstriper is offline
