290 SC listing >
290 SC listing
290 SC listing
Old 10-01-2016 | 10:27 AM
Default 290 SC listing
Put a few hours on my 290sc finally and have noticed it consistently lists to the port side while under way.... Have to run quite a bit more tab on that side to level it out..
Is this normal ?
My fresh water tank in not installed and I do have two batteries on the port side..
Also I'm running a RH 5 blade prop.. Could that be the culprit ?
Anyone ever try a LH prop on one ?
THANKS !
Doug
Boatally Insane is offline
Old 10-01-2016 | 02:03 PM
Doug, I don't have issue with mine but also have battery on starboard side to offset the 2 on port. Could be prop torque from the 5 blade. Do you have fridge and microwave up front and are the tabs in sync with one another? Running a 4BL Bravo on mine with fridge and microwave.
CJSYD is offline
Old 10-01-2016 | 08:22 PM
Is this normal ?
THANKS !
Doug
Mine did the same. Relocated a battery to stbd and she flies very straight now. I was doubtful it would completely correct the list. Thus I was pleasantly surprised.
Ryan00TJ is offline
Old 10-10-2016 | 11:01 AM
Looks like weight distribution is going ot be the answer..
I tried a LH prop on it this past weekend.. STILL listed to port..
Have to move some batteries....
