290 SC listing
290 SC listing
Put a few hours on my 290sc finally and have noticed it consistently lists to the port side while under way.... Have to run quite a bit more tab on that side to level it out..
Is this normal ?
My fresh water tank in not installed and I do have two batteries on the port side..
Also I'm running a RH 5 blade prop.. Could that be the culprit ?
Anyone ever try a LH prop on one ?
THANKS !
Doug
Is this normal ?
THANKS !
Doug
Doug, I don't have issue with mine but also have battery on starboard side to offset the 2 on port. Could be prop torque from the 5 blade. Do you have fridge and microwave up front and are the tabs in sync with one another? Running a 4BL Bravo on mine with fridge and microwave.
Is this normal ?
THANKS !
Doug
Is this normal ?
THANKS !
Doug
