Would you rebuild those 500 efi with those readings? >
Old 10-02-2016 | 06:23 PM
jeff32's Avatar
Default Would you rebuild those 500 efi with those readings?
I was surprised of the good readings i got today from my engines... Wich makes me doubt i would rebuild them!
Maybe only do top end? They run strong so not sure why i would do the bottom. What do you knowlegable guys think?[ATTACH=CONFIG]559966[/ATTACH]
Attached Thumbnails Would you rebuild those 500 efi with those readings?-image.jpg
jeff32 is offline
Old 10-02-2016 | 06:34 PM
Craney's Avatar
These engines have never been opened up have they?
Craney is offline
Old 10-02-2016 | 06:35 PM
jeff32's Avatar
No! Still sealed from merc
jeff32 is offline
Old 10-02-2016 | 06:40 PM
I would pull the heads with that many hours. Do an inspection and see what you have. I would replace the valve springs at the least with that many hours.
wannabe is offline
Old 10-02-2016 | 07:04 PM
jeff32's Avatar
I understand the top end affirmation, my question is to see if the bottom would need rebuild with these compression numbers...
jeff32 is offline
Old 10-02-2016 | 07:56 PM
Me personally, I'd just do the top ends.
boats74 is offline
Old 10-02-2016 | 08:56 PM
A leakdown will tell you if you have a bad rings, I think....
But I would just do the top ends myself.
wannabe is offline
Old 10-02-2016 | 09:03 PM
jeff32's Avatar
With those numbers, i dont think there is nothing leaking more than than it should be, neither rings, or valves! I'm lucky!!! Will see ... Tic tic tic tic....))
jeff32 is offline
Old 10-03-2016 | 09:56 AM
Bottoms are good and the solid prt of those motors, tops only needed at this,point..
Pismo10 is offline
Old 10-03-2016 | 10:11 AM
With your luck. I'd keep going. You won't get stranded. You have 3 of them
class6 is offline
