DIY Winterization >
DIY Winterization
DIY Winterization
Old 10-08-2016 | 08:11 PM
scippy's Avatar
Default DIY Winterization
Looking for any tips, illustrations and or homemade devices that you guys use when winterizing your IO engines for the winter.
I have 572's with SSM #3a's..........picked up 3 cases of the pink stuff and just want to know easiest way to run it thru the Eng.
blocks.............Everything else like oil change, fuel treatment & fogging I have a handle on......thanks, Scippy
scippy is offline
Old 10-08-2016 | 09:09 PM
jeff32's Avatar
I warm the engine up, then take the plugs off from both sides of the block, clean the sand if any in the holes, same with manifold, put plugs back on, run the engine ps again feeding the drive with the pink stuff till it comes out of exhaust, and thats it... Was lucky like that up to now!
jeff32 is offline
Old 10-09-2016 | 04:43 PM
I drain the block and hand pour almost 4 gallons (454) into the top of the hose coming off the thermostat.
When antifreeze pours out of the thermostat housing, I reattach the hose and call it done.
Ken
minxguy is offline
