props
I'm running 272 baja with 496 HO, 23 mirage plus @ 5100rpm and 68mph, tried 25 mirage plus @ 4600rpm and 65mph.
Had the 25 turned too 24 and labbed @ easy 5100 and 66mph. any suggestions would be great. WOT says 4600-5100. Im hitting rev now and the with the 23
Thanks JAFO272
Thanks JAFO272
I have the same motor, says 5000, thats why your
hitting the rev, I was spinning 5200 the other day
and didnt hit it ? Usually 68 on gaffrig speedo with
26 bravo 4 blade, what drive? I have a new 25 ballistic
3 blade I cant use because of xz, larger shaft.
jafo272
Have the same boat, a 94 272 with a 502mpi. Started with a 23 mirage and was able to attain 66 mph at 5100-5200rpm. Went through the prop testing through a mercury demo shop. Tried all pitches and 3 and 4 blade props. The best for me was the 24" 4 blade. I gained 2 mph and lowered my RPM to 4800-4900. The 4 blade is 10 times better out of the hole and is much more efficient at around 40 - 50 mph. I tried a 26" four blade but was only able to get to 65 mph and 4500 rpm.
The 4 blade will bite pretty hard and you may have to muscle the boat a little especially at top end, however you may like it!!
raiseyourdrive
09-15-2004 08:23 AM
Sorta like a labbed prop from the factory
