MEFI 4 to Nema
what guages are you adding? maybe this would help. Its what I used. http://www.nolandeng.com/rs11.php
But what guages are you wanting to add? Because although they dont do the conversion you want they can take the signal from your motor and convert it to nema2000.
I used the above device and did tach, oil temp, oil pressure, water temp hmmm forget what else.
Just thought although its not mefi 4 to nema it still may be of use to you.
