500efi Saga Continues >
Old 11-06-2016 | 10:19 AM
Default 500efi Saga Continues
So after replacing the entire valvetrain to get rid of lifter noise, upon removing engines this year for transom work; the rear exhaust valves are toasted. Heavily corroded looks like reversion. Engine has to come apart for the 3rd time. Anyone have issues with reversion on stock 500efi setup? Exhaust is cmi e top headers. They have been Pressure tested numerous times. No issues.
Before the rebuilds there was a lot of carbon build up but valves did not look like they look now. It's a stock cam, Johnson lifters, isky springs, scorpion 1.7 rockers, and trend push rods. Any help is appreciated. Thinking we may have to go dry to prevent this happening again. Going on 20k for top end rebuilds...should have left them alone.
1MOSES1 is offline
Old 11-06-2016 | 12:31 PM
F-2 Speedy's Avatar
Are you running mufflers ??
F-2 Speedy is offline
Old 11-06-2016 | 12:34 PM
No
1MOSES1 is offline
Old 11-06-2016 | 01:34 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Originally Posted by 1MOSES1
No
Switchable exhaust?
Picture of your exhaust angles and tips may help.
Sydwayz is offline
Old 11-06-2016 | 02:26 PM
Originally Posted by Sydwayz
Switchable exhaust?
No switchabke exhaust. I'll take picture of tailpipe but there is nothing fancy about it. It's the standard cmi e-top. Termination of water into exhaust is 16-20" down pipe.
1MOSES1 is offline
Old 11-06-2016 | 03:59 PM
jbraun2828's Avatar
Check your tail pipes for cracks
jbraun2828 is offline
Old 11-06-2016 | 04:55 PM
I looked. Tails and headers are in mint condition. No rust, no corrosion, etc.
1MOSES1 is offline
Old 11-06-2016 | 05:08 PM
Cylinder #8
https://i.imgur.com/qS4uLE7.jpg
Cylinder #2
https://i.imgur.com/uhJB95q.jpg
I think it's reversion because both motors are identical in terms of pattern. Rear cylinders are bad. Front of engine appear good.
1MOSES1 is offline
Old 11-06-2016 | 06:22 PM
SB
#8 is horrible. Yuk.
Rear cylinders primary tubes are the 'bottom' ones. Could be water leaks,,,,could be just the ignition timing. You pulled heads to get redone right ? Anything else touched other than removing heads, intake, dist, and exhaust ?
SB is offline
Old 11-06-2016 | 06:29 PM
I didn't do the work...paid someone to do it. but I am only aware of heads, intake, exhaust, and dist coming off. Heads don't appear to be rotted.
Lower end was not touched
1MOSES1 is offline
