Good Thing I deceided to rebuild Transmissions >
Old 11-07-2016 | 03:01 PM
Default Good Thing I deceided to rebuild Transmissions
I thought it would be a good idea to freshen up the trannys . Good thing this what I found in the bellows on the port side . I have either a bad rear seal or I inadvertently over filled it at one point . Either way I have avoided a major disaster .
RG. [ATTACH=CONFIG]561288[/ATTACH]
Attached Thumbnails Good Thing I deceided to rebuild Transmissions-img_20161031_191616.jpg
Rick G is offline
Old 11-07-2016 | 06:53 PM
jeff32's Avatar
Oh! Nice soup!!!
Always better to check for small surprise in case instead of waiting and having the big surprise!
jeff32 is offline
Old 11-07-2016 | 08:15 PM
Check the front seal, I`ve had those pop out on me 4 times now.
ICDEDPPL is offline
Old 11-08-2016 | 04:58 AM
Full Force's Avatar
Isn't that what you were fighting when I met up with you in Sandusky that day??
Full Force is offline
Old 11-08-2016 | 08:08 AM
No, that was the carrier in the extension box seal Stupid boats
ICDEDPPL is offline
Old 11-08-2016 | 08:20 AM
Thanks Dan , I will check . Going to do complete tear down and rebuild in any event . Going to replace bearings, clutch plates, seals and gaskets at a bear minimum.
I was planning this as my winter project along with other routine maintenance like rebuilding sea water pumps , fixing oil leaks , new plug wires etc.
Cheers RG.
Rick G is offline
Old 11-10-2016 | 01:41 AM
mmb
Red lock tite on front seal when installing it holds to 500psi... But what would a former Cat Technician know you guys are geniuses!!
I use green lock tite (high strength retaining compound) on the back seal.
Or maybe the transmission in these boats are just bad and we can start a thread telling everyone that has a trans to buy a bravo boat!!!! OSO Tech is top notch!!
mmb is offline
Old 11-13-2016 | 10:32 PM
Anyway....
Rick, I use Locktite 648 on all the seals now, it`s the correct "retaining compound" for seals.
If in fact it is the front seal it`s not supposed to be flush with the case, there`s a tool that sets it where it`s supposed to be since there no "bottoming lip" . It can be a pain , order extras.
ICDEDPPL is offline
Old 11-14-2016 | 01:01 PM
Thanks Dan good advice .
Going to shop tonight to pull the other motor . Then start the tear down process .
I actually built a receiver that inserts to an engine stand to accommodate the C72 / 71 tranny .
Rick G is offline
