Cam Specs
Old 11-08-2016 | 01:44 PM
Default Cam Specs
What are the cam specs for the 900sc merc engines? I do know that they are solid roller.
C1000 is offline
Old 11-08-2016 | 02:14 PM
The solid roller ones come into play in the 950-1075 sci engines. I will double ck however I am pretty certain the 900 sc still used the old original flat tappet cam.
getrdunn is offline
Old 11-08-2016 | 02:24 PM
Looks like it might be the same as the sci specs.
900 SC, [email protected], 252, lift is .672
Exhaust@ .050. 257, lift is .672
I know these are the same specs are what I got from a member on the 1075 sci and do believe the 950-1075 sci all have the same solid roller.
getrdunn is offline
Old 11-08-2016 | 02:28 PM
For some reason I thought the 900 was different but evidently was wrong according to another post that provided the 900 specs. You can order the cams from bullet.
getrdunn is offline
Old 11-08-2016 | 02:47 PM
800sc used a flat tappet hydraulic. 900sc was a solid roller.
MILD THUNDER is offline
Old 11-08-2016 | 04:56 PM
Correct. Did 900 sc use same as 950-1075 sci roller though?
getrdunn is offline
Old 11-08-2016 | 05:09 PM
i copied and pasted 900 sc cam specs from another thread. Those specs are the same as what I have for 950sci-1075sci. So evidently 900"sc" - 950"sci"/1075"sci" are the same. If anyone knows any different please post.
getrdunn is offline
Old 11-08-2016 | 06:16 PM
i did not know merc had a sc950,i thought sc850/1075,and the sc900 the op is asking about.
mike tkach is offline
Old 11-08-2016 | 07:07 PM
The part #'s for the camshafts, are not the same in merc's parts diagrams, so I would say, no , the 900sc carb engine, did not use the same camshaft , as the 1075 EFI.
The 900sc's were known to be valvetrain eaters. I wanna say they had something like 714 lift solid rollers. They used conventional rockers, basically old school blown big blocks like alot of us have. Nothing fancy.
Personally, If I was rebuilding a 900sc merc, I would go for a milder camshaft setup .
Old 11-08-2016 | 07:24 PM
Your absolutely right Mike. Not sure why I had 950 on the brain other than having vertigo for a week now (Not fun btw) I dug into this a while back for some personal information a while back but evidently screwed up on the 950sci rather meant 850sci. Regardless if op does a Google search on 900sc cam specs there is a link to OSO dating back to 2002 with above posted specs for 900sc.
Not much info on any of those cams going past the old 525-800sc hyd flat tappet .559 lift cam that was used forever it seems.
There are a few things I'd like to add but don't want to confuse OP more than I already have.
getrdunn is offline
