Mercruiser 496 Fuel Pressure Regulator-2004 Cool Fuel >
Old 11-25-2016 | 10:49 AM
Rage's Avatar
Default Mercruiser 496 Fuel Pressure Regulator-2004 Cool Fuel
Specification says Fuel Pressure Boost Pump 7 psi (48 kPa), EFI Pump 43 psi (296 kPa). This is for key on engine not running, fuel pumps running. What will/should be the actual fuel pressure with intake manifold vacuum reference to fuel pressure regulator....
1.) at idle?
2.) at WOT?
Rage is offline
Old 11-25-2016 | 08:06 PM
1) idle if I had to guess 32-34
2) wot should be the same as key on engine off 43 (zero vacuum)
underpsi68 is offline
