LH Prop
Old 12-01-2016 | 10:32 AM
Default LH Prop
Has anyone had any experience spinning a LH. prop on a single engine boat. (290SC) Any info is appreciated.
LJ 290SC
LJ 290SC is offline
Old 12-01-2016 | 11:17 AM
My Cig 20 is setup this way. Although, I'm left side helm as well. Typically, with a RH helm a RH prop will counteract the weight of the driver. You may see slightly more list to the right.
Holy Smokes is offline
Old 12-01-2016 | 12:57 PM
Revelocity's Avatar
LJ 290SC
The first VR-1 that was sent to the Powerboat Magazine trials in 2002 or 2003 spun a left hand prop for extra top end. As I recall PB had nothing but priase for the boat's handling. I have no doubt that someone here has first hand LH prop experience to offer!
Revelocity is offline
Old 12-01-2016 | 02:50 PM
Not a Velocity, but a I have a older fast IMO Vee. I bought a pair of bravo's and ran the LH 28 First. I have never even tried the RH after the boat runs so flat and fly's level with the LH. Most of the single Fountains run a LH as well.
Good luck!
TxHawk is offline
Old 12-01-2016 | 04:44 PM
LJ 290SC
Always ran RH on mine. The VR1 hull was designed with it in mind......
22* deadrise, conventional lifting strakes with a 3" high notched transom. 1' wide pad. Pad is offset 6.5" to port of keel and 5.5" to starboard to offset the right hand turning prop.
Ryan00TJ is offline
Old 12-13-2016 | 08:19 PM
I tried a LH prop on my 290SC to see if it would correct the listing issue I have..
Normal prop is a RH Hydromotive 25 pitch 5 blade... I tried a 26 pitch Bravo I LH...
Aside from the anticipated increase in slip going to a 4 blade, the handling did NOT change nor did it fix my list...
I was a bit surprised it didn't make any difference on the Velocity
A LH or RH prop makes a HUGE difference on my Corsa
Boatally Insane is offline
