Velvet Drives ??? >
Velvet Drives ???
Velvet Drives ???
Old 10-05-2002 | 07:37 PM
XCAV8's Avatar
Default Velvet Drives ???
What has to be done to change from the merc trans to the borg warner velvets? i'm told the mercs have a bell housing on them and the velvet drives don't ?????
XCAV8 is offline
Old 10-05-2002 | 08:11 PM
Biggus's Avatar
Yes, you are correct, you will need the tranny, bellhousing. You will also have to change the flywheel and starter because the starter will need to be moved from the block to the bellhousing. Also you will need to change the yoke on the drive from a female spline to a male spline. You will also have to move the motor forward about 3" to accomodate the longer Borg tranny/bellhousing.
The best way to do this is to buy the stuff from someone who has removed a TRS set up.
Biggus is offline
Old 10-05-2002 | 09:18 PM
XCAV8's Avatar
Thx Biggus,
The boat i bought has a set of both , the trs drives are now set up for the Velvets , with 540's, i'm am not getting the 540's but i want to put the velvetdrive with the 454's 440 h.p. motors i'm getting with the boat... will the 540 bellhousing bolt up to the 454? and will the 454 mount to the 540 motor mounts ?
XCAV8 is offline
Old 10-05-2002 | 09:21 PM
xcav8; My question is, "Why would you want to do that?" The MercTransII can be beefed and upgraded for lots less money and hassel by a real knowledgeable A.T. shop and handle more H.P. than the TRS drive will handle. Everything will stay the same in the boat and you won't add any extra weight. Been there/done that. --- Jer
jpclear is offline
Old 10-05-2002 | 09:27 PM
OK, you were writing at the same time I was so forget my last post. The bolt holes to mount everything are basically the same from 540 to 454. --- Jer
jpclear is offline
Old 10-05-2002 | 10:59 PM
XCAV8's Avatar
jp thx for the info.... this is the reason i want to use the velvet drives.....
http://www.offshoreonly.com/forum/sh...t=before+bravo
XCAV8 is offline
Old 10-06-2002 | 09:31 AM
Audiofn's Avatar
Charter Member #232
Huber can beaf up your Merc transmisions.
Jon
Put your best foot forward!
Audiofn is offline
Old 04-13-2003 | 08:45 AM
XCAV8's Avatar
Getting ready to start this project,(prob next weekend) so i thought i'd bring this thread back to the top, i'm sure i will have lots of ???? 's once i get into it.......
XCAV8 is offline
wannabe
Drives and Lower Units
10
02-19-2008 08:49 AM
Monty
6
02-26-2004 05:30 PM
Monty
6
10-15-2003 12:36 PM
karsntrux
8
03-04-2003 10:26 PM
GO4BROKE
04-28-2002 09:48 AM
