Manual oil temp control?? >
Old 12-16-2016 | 09:04 AM
Full Force's Avatar
Default Manual oil temp control??
Talking to a friend, manual oil tempcontrol came up, like using a valve to manually control how. I how much oil goes to the oil cooler and not using the mi h more expensive stat, just needs to be plumbed in, rounds round circle guys use this system to control oil cooling, has anyone tried this in marine? Makes sense then I can control less oil to cooker in may when lakes cold and open it more in summer when it's warmer...
Full Force is offline
Old 12-16-2016 | 09:42 AM
pretty hard to beat the t-stat system.the last thing i want is a valve to constantly be messing with.
mike tkach is offline
Old 12-16-2016 | 09:49 AM
get a cooler bigger than your needs and thermostatically control the oil,,been working that way for me and all my boating friends for years,,ocean and lakes are ever changing loads on the hull,,roundy round isn't.
sutphen 30 is offline
Old 12-16-2016 | 11:20 AM
the mercury marine t stat oil device sends very little oil to the cooler until the t stat starts to open,it is the control valve per say.
Old 12-16-2016 | 12:01 PM
Full Force's Avatar
Yes gonna look for those probably, the valve was a cheaper idea lol
Figure with my oil coolers being good that I would nitbhabento mess. With it much I dunno.
Old 12-16-2016 | 10:55 PM
I'd put one of the OT2 m2m on each engine and be done with it. easily plumbed in and relatively cheap.
http://97.74.32.155/files/thermos$.pdf
mickeymcclgn is offline
Old 12-21-2016 | 09:52 PM
You could hook up a string and a return spring and if you need more oil thru the cooler just pull the string.Maybe drill some holes thru the hatch.. I like it.
ICDEDPPL is offline
Old 12-22-2016 | 05:09 AM
No no no. Run the oil lines up to the helm and mount the control valve right by the throttles. I would use the type with a round nob. Like for a garden hose. Heck probably just use garden hose for the oil lines. Make sure you get the temperature rated stuff. Make sure you use 5/8" hose as well. Don't want to restrict flow.
Black Baja is offline
Old 12-22-2016 | 07:23 AM
I used a canton thermostat and worked great..if its not broke don't fix it...my .02
ezstriper is offline
Old 12-22-2016 | 07:46 AM
SB
SB is offline
