disk brake conversion???
I've got one drum thats shot is it worth changing over to disk's while I'm at it????I pull a 31 Sonic about 7500 lbs pluss gear and fuel..looks like you can do it fo around $200 per axel....
If your boat has a sail do you ride a horse to the ramp?
Dyno
I switched mine over 2 yrs. ago for 300.00 on 2 axles and have had no trouble.www.kodiaktrailers.com
They stop great and you can buy replacement pads at auto zone.
i basicly just rebuilt my trailer!! from ALL new springs to bearings/races....the calipers are from a 1990 beretta (sp)....took sometime to figure out what the hell they used...$12 per caliper...they car/truck(rotors) they use are FAR cheaper to buy at your local disount auto part store
I converted mine from single axle drums (for some stupid reason) to single axle discs
and it didn't stop as good). Last spring I added discs to the other axle...WOW
them suckers DO stop!
I have about 7500lbs behind a Tahoe and it stops like its not there.
them suckers DO stop!I have about 7500lbs behind a Tahoe and it stops like its not there.
Dyno, I just switched my 32' trailer over from surge drum brakes to surge disc with stainless rotors. They came from Northern Tool Co. Approx. $110 each wheel. They come with hubs and bearings, etc. A great kit considering that my bearings needed to be replaced anyway. The only thing you have to do when switching is punch a hole through the diaphram in the rear of the master cylinder(this info is in the kit). I have had no problems with mine since replacing. P.S. Had to add a lockout reverse solenoid at the master cylinder to allow you to back up @ approx $45
bit the big question remains ......is it worth it??????I pull my boat about 3-5 times a year, a couple trips up north......about 500 miles round trip..
I think so,I always had trouble with the linings coming of the shoes and a trailer that is pulled alot is as bad as one that sits because the linings will still rust at the rivets and the shoes.Disc are probably 90% decrease in maintaince.Just my .02
rebuild stock brakes every 2 years/used or not!
vs no rebuilds in ? years for disks?
It's a no brainer for me, I hate doing brake cylinders and shoes, not to mention the time and bother to do it.
Do the discs....you will never regret it and resale will be higher also.
Robbie Racer
2
04-15-2005 09:07 AM
