Oil Lines
Old 01-09-2017 | 09:08 PM
Default Oil Lines
Need to replumb, any recommendations on hose for engine oil and transmission lines. Not really wanting to deal with SS braided lines and aluminum fittings. The push lok style seems like a good idea.
ezrizer is offline
Old 01-09-2017 | 09:42 PM
vintage chromoly's Avatar
Stainless AN hose is a pain in the ass and the hands.
I used the black braided AN and black AN fittings.
If you want to save a few bucks, push lock is nice stuff too.
vintage chromoly is offline
Old 01-09-2017 | 10:00 PM
bck's Avatar
bck
Charter Member#568
Look up the actual part # with Eaton or whoever makes it. Check its temperature rating. Don't just buy a type of hose because it says it's good for oil.
Straight bottoms and flat decks
bck is offline
Old 01-09-2017 | 11:02 PM
i have done several with earls push lock hose&fittings.if you don,t heat the ends with a heat gun it sucks.
mike tkach is offline
Old 01-10-2017 | 05:21 AM
I have used Aeroquip push lock for oil plumping with no issues.
badluck is offline
Old 01-10-2017 | 06:17 AM
I used the aeroquip twist lock and works well, just be sure to use the hose and matching fittings from same manufacture
ezstriper is offline
Old 01-10-2017 | 06:38 AM
Good point.
Mixing and matching hose ends and hose from different suppliers doesn't always work.
I've been buying from: getfast1.com
Old 01-10-2017 | 10:20 AM
I used the push on hose and fittings from CP Marine as the system is pretty friendly for the weekend warriors. I'm sure there's better deals though. Does anyone have any experience with the push locks blowing off? I'm running 70psi and put an ugly hose clamp on the ends just to be safe.
Baja Rooster is offline
Old 01-10-2017 | 12:35 PM
14 apache's Avatar
Buy the pinch clamps they look nice when done and work great.
14 apache is offline
Old 01-10-2017 | 02:38 PM
Team Archer's Avatar
We use all XRP hose and ends with there clamps and have had no failures but you need to use the clamps with there plyers.It comes in many color combinations.
Team Archer is offline
