Trailer Winch
Old 01-11-2017 | 09:39 PM
scippy's Avatar
Default Trailer Winch
I orderd 2 bow blocks from Myco and will be fabing up a new bow stop for the Mistress also changing out the old
original rusted trailer winch...........What would be a good replacement?...and what's better cable or strap?.....thnx
scippy is offline
Old 01-11-2017 | 10:29 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I've had both. Prefer strap. The strap will never cut your hand open.
The strap is easier to deal with and install, but it's a bigger pain the ass to get wound tight. The strap stretches as it tightens down on the spool for the first few uses. The cable doesn't really do that, but the cable can get bound over itself which is another PITA, and that's when you will cut your hand. Ask me how I know that.
Regardless, if you have a straight bottom boat, ensure you have a safety chain that you latch before you pull up the ramp. Both straps and cables can break.
Sydwayz is offline
Old 01-12-2017 | 11:33 PM
scippy's Avatar
Sydwayz...........I have cable wire now and it can get tangled like christmas lights plus it has splintered...ooch!...I'll go with the strap...can you recommend a good winch?...I have a 35" Cig
scippy is offline
Old 01-13-2017 | 05:10 AM
I am buying a Fulton. not sure the model, but its the one that has the cover on it. It looks way better
class6 is offline
Old 01-13-2017 | 07:29 AM
I had that Fulton with the cover for about a week - some cast piece broke off on the inside, and wouldn't work after that. I sent it back and got the regular style Fulton (open, with a strap).
ALL_IN! is offline
Old 01-13-2017 | 09:14 AM
I have had both - and would go with a strap hands down. I had a strap break and all I got was a "slap in the face" if it would have been a cable I would guess it would have cut me.
3pointstar
3pointstar is offline
Old 01-13-2017 | 12:28 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
If I was starting from scratch with a winch setup today, it would be these two:
https://www.crofttrailer.com/fulton-...y/#page=page-1
http://www.etrailer.com/Accessories-...n/F501204.html
Fulton also makes a 3200 lbs. winch, which is easier to find. But I think with the heavier setup, they give you better gearing/leverage.
Sydwayz is offline
Old 01-13-2017 | 01:12 PM
Dutton-Lainson. You can call them and get someone knowledgeable on the phone if you need a replacement part. I had rebuild kits for my tongue jack and winch within a few days. They've been in business since 1886 for a reason. I also prefer strap over cable.
https://www.dutton-lainson.com/prodd...php?prod=15440
https://www.dutton-lainson.com/prodd...php?prod=14881
Speedracer29 is offline
Old 01-13-2017 | 02:51 PM
[QUOTE=Sydwayz;4519333]If I was starting from scratch with a winch setup today, it would be these two:
[url]https://www.crofttrailer.com/fulton
I just purchased a F2 Fulton, 3200# 2 speed trail winch- it just arrived today. I purchased it from Star Marine - (I have not connection with Star Marine) - it was less than Amazon and shipping was very inexpensive - I believe I got it in less than a week- it was a little shy of $150.00. Obviously I haven't put it on our trailer but it sure looks and feels very robust. It has the standard mounting and came with a "strap with hook". Spring can't come fast enough to northern Indiana
3pointstar
Old 01-13-2017 | 03:15 PM
I would seriously consider electric! I don't power load so I typically shallow dip the trailer so I can use the bunks to help align the hull with the trailer. This allows me to float the boat about 3/4 of the way on. I then hook up the winch and jump in the truck. I start winching with the remote while slowly backing in so the boat isn't dragging on the bunks. Once the boat is on the rubbers in the front the girlfriend hooks the safety chain and away we go.
Makes for super fast loads!
502ss is offline
