Gen V heads on a Gen IV block head gasket? >
Old 01-20-2017 | 10:16 AM
Default Gen V heads on a Gen IV block head gasket?
Getting conflicting information on the correct head gasket for 088 heads on a Gen IV bowtie block. I bought 17049 Felpro for marine application because I read on many forums that you need to use a Gen IV head gasket to match the block. I called Fel Pro tech line and ended up having to call back 3 times fro different reasons and got 3 different answers from a 17046 (too small of a bore), 17048 (Gen VI block) and a 1093.
thanks
Tahoe540 is offline
Old 01-20-2017 | 01:11 PM
17048 is the gasket for putting a mark 4 head on a gen 5 or gen 6 block.i believe this will work for you.
mike tkach is offline
Old 01-20-2017 | 01:26 PM
Call Felpro or Cometic, they will help you out.
Jonesyfxr is offline
Old 01-20-2017 | 02:58 PM
he called fel pro 3 times and still is not sure what to use,even their tech line can,t answer his question.
Old 01-20-2017 | 06:11 PM
Thanks for the information. And yet the saga continues. I live in Sparks and we have our own Summit here so it is easy to go and get parts and they also have a parts counter with guys to help you and they could not even find something I would use. They suggested a 10171 which is just a gen IV head gasket.
I also read on another forum they called Cometic for this application and they ended up telling them they had nothing. I will try and find it.
Tahoe540 is offline
Old 01-20-2017 | 08:21 PM
SB
Pretty sure it is the 1047.......double check.....I am not responsible for your mishaps...lol
https://www.summitracing.com/parts/fel-1047
SB is offline
Old 01-20-2017 | 08:25 PM
SB
BTW: will be a better search if you use these terms: Mark IV block and Gen V heads.
GEN IV will not, since it's official, and thus more used name is Mark IV.
SB is offline
Old 01-20-2017 | 08:55 PM
SB thanks, I actually have those in my cart right now and will be getting those.
Tahoe540 is offline
Old 01-20-2017 | 09:13 PM
SB is correct. I run 1037 gaskets on my 525sc. MK IV block with Gen 5 heads. I have 60 hours with 5lbs of boost. No Issues. I have a 454 so my gaskets are a smaller bore.
79formula is offline
Old 01-20-2017 | 10:20 PM
+2 for the 1047
endeavor1 is offline
