4 Blade #6 speedmaster props, what rake? >
Old 01-20-2017 | 10:19 AM
Default 4 Blade #6 speedmaster props, what rake?
What rake/s were 4 blade #6 speedmaster props available in?
JRider is offline
Old 01-21-2017 | 05:42 PM
15-18-21 rake -The higher the rake more bow lift will occur. Just Guessing LOL
Scooter is offline
Old 01-22-2017 | 09:54 AM
I believe majority were 15*
ICDEDPPL is offline
Old 01-22-2017 | 02:16 PM
I know the 5 blades come in those rakes, I want 4 blades with higher than 15* rake. Like 18 possibly
JRider is offline
Old 01-22-2017 | 02:30 PM
27daytona's Avatar
Did you get any test time with your DCB? What is the boats attitude with your current set of props?
27daytona is offline
Old 01-22-2017 | 06:53 PM
I came to the conclusion that it needs bow lift, 4 blades worked better than the 5 blades I tried running. The 5 blades were 15 or 16* with some cup at the tip. They only worked in rough water. The four blades that came on the boat worked better. I'm having thoughts of cutting the sub boxes out of the bow and moving the batteries. It bow steers when not aired out, needs some weight loss for sure
JRider is offline
Old 01-22-2017 | 07:04 PM
bbladesprops's Avatar
Offshoreonly Advertiser
We marketed and sold the 4 blades at 15 degrees.
However, we had consistent blade droop due to to wax maintenance that ultimately made the actual rake about 14.5 degrees.
We do get some 4 blade "long hubs" in our CR program. Call us and we can check inventory for you.
Brett
Brett
[email protected]
bbladesprops is offline
