engine oil temp sender >
Old 01-24-2017 | 07:52 AM
F-2 Speedy's Avatar
Default engine oil temp sender
What are you guys using, I've looked on line and cant seem to find one, I send a message to Livorsi but have not heard back
thanks
F-2 Speedy is offline
Old 01-24-2017 | 07:58 AM
Full Force's Avatar
http://www.cpperformance.com/p-13075...si-gauges.aspx
Full Force is offline
Old 01-24-2017 | 07:59 AM
Full Force's Avatar
Summit also carries them if you have one to get the numbers off side. It's a standard sender for many gauges.
Old 01-24-2017 | 08:05 AM
F-2 Speedy's Avatar
thanks, new builds, I don't have one now..........I think the gauges are Autometer but the boats @ the lake
Old 01-24-2017 | 08:28 AM
Full Force's Avatar
I am adding auto meter gauges and the senders look to be the same.
Old 01-25-2017 | 07:32 AM
you have to use whatever your gauge requires, not all the same, may look idenitical but mine was 100 deg off, CP can tell you what fits what
ezstriper is offline
Old 01-25-2017 | 07:35 AM
F-2 Speedy's Avatar
Correct EZ............ CP sent me a catalog of the senders for the Autometer gauges
Old 01-25-2017 | 07:54 AM
Ken,
Sent you a price list what I was quoted for Autometer gauges and sending units from Diamond Perfomance. I was told the sending unit is specific to the brand of gauge
endeavor1 is offline
Old 01-25-2017 | 07:59 AM
F-2 Speedy's Avatar
Now all I have to do is drive four hours to see if their half sweep or full sweep, it makes a difference.
thanks Chris
Old 01-25-2017 | 04:22 PM
Anyone have their oil temp sender in an oil pan port. I know some like it before cooler and some who like it after cooler. I always figured if the the sensor was close to the pump you'd actually be getting a pretty accurate reading. Kinda like my water temp sensor I used a T fitting and installed it there. This was a project in the works that never saw the water so I never had a chance to see how either worked but the locations made sense to me. Especially for water temp sensor if your running x-over an bypass.
getrdunn is offline
