Go Back  Offshoreonly.com > Owners Forum > Sutphen
Water pick up question >
Old 01-29-2017 | 10:26 PM
Default Water pick up question
Is there enough material on the bottom of a 31' for a water channel like the one in the picture
finishline is offline
Old 01-31-2017 | 09:05 PM
seems a little to deep,shouldn't be more than 1/4" at best.mine are basically flush w/ no groove,,plenty of water and speed.
sutphen 30 is offline
Old 01-31-2017 | 11:12 PM
Do you have a picture of your set up? I was considering running a single pick up to a large strainer and running both motors off that. Any thoughts
Old 02-01-2017 | 04:59 PM
Do you have a pickup on both sides? Did you buy the boat set up this way ? Have you run the boat?
Boxer is offline
Old 02-01-2017 | 06:40 PM
I'm looking for advice I have no pick up now.
I see several boats with the channel cut in thought it would work well since it's not really hanging down
Old 02-01-2017 | 07:15 PM
Im interested in this as well. I will need to feed my two stage water pump that will feed the motor and the intercooler. I was planning on using the drive water pickup to a large sea strainer and adding a thru hull like in the pic as well. Would the drive p/u and thru hull be too much?
IGetWet is offline
Old 02-01-2017 | 08:12 PM
I thought that was a pickup on your boat. I would check with CP marine or Stainless Marine. The pickup doesn!t have to extend too far below the bottom of the boat, depending on the style.
Boxer is offline
Old 02-02-2017 | 07:23 AM
A pick-up doesn't need to be below the bottom that creates drag.....water goes around a corner. pick-up can be above the bottom just a bit and the leading edge can be sharp. It' s not rocket science
MSGANGWAY is offline
Old 02-02-2017 | 07:42 AM
At higher speeds, 90mph water is still flowing around a corner? Or is that when the groove in the hull would come into play?
IGetWet is offline
Old 02-02-2017 | 08:32 PM
Can you sent me pictures of some different water pickup options you guys use MSGANGWAY. I know it's not super complex to figure out just wanted to have a little Winter Sutphen conversation on what people are running! my imco drives are cooling the drives only so I'll have to cool the motors!
