SCX  Upper to Xr lower >
Old 02-02-2017 | 12:33 PM
Default SCX Upper to Xr lower
Question, Will an IMCO SCX Upper bolt onto a Bravo XR Lower without an adapter or any special parts needed.
253 is offline
Old 02-02-2017 | 01:54 PM
bor's Avatar
bor
If I'm right you need another vertical shaft kit ( shaft and bearings )in the lower , maybe give Imco a call to ask if so I probably have it on the shelf for you unused cheaper then Imco sell it for .
Pm your email or mobile I can send you pics and part #
Thx bor
bor is offline
Old 02-02-2017 | 02:36 PM
needs an adapter sleeve, around 200 bucks if memory serves.
Pwraddr is offline
Old 02-02-2017 | 02:38 PM
http://www.imcomarine.com/cal_store/scx-sc-coupler.html
Pwraddr is offline
Old 02-02-2017 | 04:10 PM
Not worth risking running metal off those junk xr gears through your beautiful upper, or even worse.....
offshorexcursion is offline
Old 02-02-2017 | 04:44 PM
Panther's Avatar
Frank's Marine Service
You'll need an adapter spline coupler, that's it.
I put one on an SCX this summer because the boat lost 10mph with the SCX lower and the owner didn't want to fuss with it. I'm not a big fan of the SCX lowers due to the speed loss I've seen on a few boats.
Panther is offline
Old 02-02-2017 | 10:35 PM
This helps a lot,, thanks to everyone for all the help.
Mike
253 is offline
Old 02-03-2017 | 08:17 AM
offshoredrillin's Avatar
I ran XR lowers on mine, then went with the imco SC lower -2 and picked up 4 mph
offshoredrillin is offline
Old 02-03-2017 | 10:03 AM
I'm eventually going to switch from my XR to the SCX. Did you ever have issues with the XR lowers? And how did going shorter affect the rest of the boat?
Getting on plane, manuevering,etc...? Thanks
Michael
mbjhachapi is offline
Old 02-04-2017 | 08:49 AM
Michael
i ran them for the end of a season on the stock xr lowers, when i took them off the lowers gears were worn out, but they did have about 300 hours on them. It jumped right up on plane with the -2 lowers and i got 92 mph out of it with 30 pitch props, i tried labbed 32s and the boat didnt like it. handling is great with the -2s. im going to try stock 32s to see what it does and may even go down a half inch deeper.
