Questions about mounting rams on Lathem setup >
Old 10-08-2002 | 12:37 PM
blue64drop
Default Questions about mounting rams on Lathem setup
Below are a few shots of my chaparral villainIII
I want to put lathem external steering (dual ram) setup on my boat but I have limited real estate on my transom. Can I mount the rams on the bottom of my swim deck? I don't have enough room between my gimble housing and my trim tabs to mount them on the transom.
Has anyone ever mounted the rams anywhere other than directly on the transom?
Attached Thumbnails Questions about mounting rams on Lathem setup-transom-004sm.jpg
Old 10-08-2002 | 12:38 PM
blue64drop
Attached Thumbnails Questions about mounting rams on Lathem setup-transom-003sm.jpg
Old 10-08-2002 | 12:39 PM
blue64drop
Attached Thumbnails Questions about mounting rams on Lathem setup-transom-002sm.jpg
Old 10-08-2002 | 01:12 PM
Put on an IMCO ext box with the side ears for the steering rams.
cobra marty is offline
Old 10-08-2002 | 04:24 PM
32storm's Avatar
I wouldn't mount steering rams to bottom of swim platform. Structurally, it will not have the integrity of mounting to transom. This a key anchor point for the steering cylinders. Most external systems require that the steering rams are mounted on the centerline of the input shaft of the outdrive. That appears to be aprox. just above furthest tab cylinder.You may want to contact WPM, Marine Machine, Keith Eickert,etc. They may be able provide a special bracket.
32storm is offline
Old 10-08-2002 | 06:05 PM
cigarette1's Avatar
Member #2 ....Jeeezz
Check with Imco. They have a short ram that might fit as is. But, it looks like you may have to relocate your trim-tab rams ?????
cigarette1 is offline
fastlane40
13
07-15-2008 09:51 PM
Dono
06-16-2005 01:15 AM
Wild
1
05-19-2005 11:43 AM
Poorsche
1
05-17-2004 07:49 PM
tunnelvision
35
11-20-2002 02:13 PM
