Mechanical fuel pump >
Old 02-13-2017 | 05:57 PM
F-2 Speedy's Avatar
Default Mechanical fuel pump
Ive not bought one in years, what would you recommend to support 650 hp, to be driven off the sea pump
thanks
F-2 Speedy is offline
Old 02-13-2017 | 06:36 PM
I would look into C&S. great pumps and real nice brackets
class6 is offline
Old 02-13-2017 | 06:43 PM
Full Force's Avatar
you can buy the Baker and install the diphram part onto the merc base, at least that's what I was told when I was looking, I ened up doing Dart blocks and was able to just use the pump As is..
Full Force is offline
Old 02-13-2017 | 06:54 PM
Any bolt together style pump, you can bolt the bottom on to the merc top. I used the jegs 170gph with a Holley regulator and it has worked very well.
Unlimited jd is offline
Old 02-13-2017 | 06:58 PM
A holley 130 gph is all I've ever used.
getrdunn is offline
Old 02-24-2017 | 03:28 PM
F-2 Speedy's Avatar
Im bringing this back up, went into my local speed shop ( Star Performance ) looking for a pump, looked at the Holley 12-454-20 and told them it was going to mount kinda upside down and they said no way ?? Im ready to order two of something but dont know exactly what. Sea pump mounted
Old 02-24-2017 | 03:29 PM
F-2 Speedy's Avatar
Why wont they bolt directly to the sea pump, new complete unit ?
Edit: this one ?? ...http://www.jegs.com/i/Holley/510/12-454-20/10002/-1
Old 02-24-2017 | 05:10 PM
The merc sea pump style pumps, use a different arm than a regular bbc style pump
MILD THUNDER is offline
Old 02-24-2017 | 05:41 PM
F-2 Speedy's Avatar
I should of known they'd pull something like this, thanks .....
Old 02-24-2017 | 06:15 PM
I've just used the bottom of this pump bolted to the top of the merc pump. Seems to work just fine.
Baja Rooster is offline
