Post 1995 303 checkout report, please advise... >
Old 02-14-2017 | 07:46 PM
formula1's Avatar
Default Post 1995 303 checkout report, please advise...
Right off the bat, I have some questions for you 454 Mag EFI experts. This might be long,but bear with me.
First, the dealer sales rep told me that they replaced the twins with "drop in crate motors" that have between 15 and 20 hours on them. Come to find out today by their mechanic that they actually were long blocks with all new accessories and the intakes, fuel injectors and dizzies were reused. Ok, that explains some of the very light corrosion one would expect on a 1995 Formula's engines. I saw the new high pressure fuel pumps mounted on the left sides of each motor. It doesn't look factory. But I guess the motors are Gen 6 vs Gen 5? Would that make sense?
Second, the motors were started "cold" (relatively speaking, lol. It was 78 degrees). The 1995 vintage Formula VDO gauges all seemed to work properly. However, the Port motor showed like 25psi of oil pressure cold and the Starboard motor registered like 38psi. FYI, I heard no bad engine noises on either at startup. We proceeded to take the boat out and run it at varying speeds. The Port motor oil PSI was still around 30ish and the Starboard motor was 40ish. Water temps read around 165-170 the whole time. Should those oil psi reading be a concern?
At all speeds the engines seemed to run smooth and fast (to me). Idle to WFO.
Third, the motors each had a PCV vent (like you'd see on a car). Each one looked like a mini K&N style conical air filter on end. Looking at the Starboard one, you could see little bubbles of oil popping out but not spilling over. The port one was a little better but the same.
Of course, the sales guy told the mechanic that we ran it hard. Hmmmm, a few hole shots, some mid range cruising (2500-4000rpm) and a one WFO run to 4800rpm for about 20-30 seconds tops. It topped out at like 72 on the speedo running 25 pitch Mirage 3 blades..
Fourth, both of the motors seemed to stumble a bit from off idle. Kinda what I would expect from an old carb motor that hasn't been run very much. But, the mechanic said all the 454 Mag EFI's and 502 Mag EFI's have a "stumble". I have never heard that but then again, I haven't
driven a boat with old big block EFI's in it. Does that sound right? If not, what would cause the slight stumble. Once the motors "clear their throats" the run perfect.
As far as the overall condition of the boat, it was very nice. However, I was told repeatedly that the boat has been inside the dealers boatel since new. Ok, then, why are you replacing the "headrest" sections on the engine hatch cover because the wood is rotten? Why does it look like I see a nasty water scum line when you lift up the step into the cabin?
I'll get some pics as soon as I can get them out of my phone (the memory is full now, lol).
That is all I can think of now. Any input would be appreciated!
formula1 is offline
Old 02-14-2017 | 08:22 PM
formula1's Avatar
I'd post a couple pics but it says I can't post attachments?????
formula1 is offline
Old 02-15-2017 | 04:51 AM
Dealer boat or consignment. I would get a survey.
Rattlesnake Jake is offline
Old 02-15-2017 | 05:53 AM
badmonkey's Avatar
You need to be a paying member....
badmonkey is offline
Old 02-15-2017 | 08:28 AM
if you use photo bucket you can just copy the link from the picture and post them here.
RGPIII is offline
Old 02-15-2017 | 09:31 AM
formula1's Avatar
Since I am slammed at work today, hopefully, people understood my post and can comment on some of the points without pics. Especially, the PCV and stumble issue
formula1 is offline
Old 02-15-2017 | 11:18 AM
I had the 454 mag mpi in my outlaw, and there was ZERO stumble. I love those motors. But even thought hey say they are new engines, I'd still get a compression test and leakdown. Finally, it sounds like a well used saltwater boat, which is a big negative to me
jwws9999 is offline
Old 02-15-2017 | 11:33 AM
TomZ's Avatar
I agree... get a survey. Some stuff seems a bit out of whack.
TomZ is offline
Old 02-15-2017 | 01:01 PM
Knot 4 Me's Avatar
1st: So you are saying there are no mechanical fuel pumps on the sea water pump housings? Instead you see electric fuel pumps mounted somwhere on the left side of each engine (assuming facing the engine)? Is the VST still intact?
2nd: I wouldn't be concerned with the oil pressure reading on the gauges until you can verify true readings with a mechanical gauge. Not unusual for old sending units/gauges to be off.
3rd: If memory serves, the original setup would have been a PCV valve on one side that crossed over and tied in to the PCV valve on the other valve cover that then connect to the bottom of the upper plenum with a single hose. Without proper venting it would not be unusual to see oil in those breathers that are just pushed into the valve covers after a run. If they kept the Lingenfelter EFI setup I'm not sure why they wouldn't have kept the original PCV setup.
4th: There should be no hesitation or stumble off idle on these engines if everything is in order. The mechanic is telling tales.
Pics would go a long way in helping determine what you have.
Knot 4 Me is offline
Old 02-15-2017 | 08:43 PM
formula1's Avatar
Thanks for the replies so far. It certainly seems like there have been alot of BS coming out of the dealership about this boat. The only thing that has been correct, is that cosmetically, it looks like a 2015 and the performance is spot on. Now it's just the details like all the things I mentioned in the first post. It urks me when I ask a question and I get a BS answer, like "all the EFI 454 & 502's do that" (stumble). Like I'm stupid or something to think Mercury would even bring an engine to market that would work like that. I don't really want to spend the $$ on a survey until I make sure this is the boat for me and I understand the issues I am dealing with (in case the surveyor is just as incompetent or on their payroll). I noticed there is a MarineMax across the river from these folks. I wonder if they would drive it there for a survey to be done....
formula1 is offline
