Super duty cold air intake
DO NOT put a K&N on ANY Powerstroke. This is a general no-no across ALL of the diesel forums.
I have a foam filter on my PSD from years ago, and it has held up well. The manufacturer is out of business now though.
AFE makes good products.
I wouldn't change it. I had an 06 and everything I read said the factory stock filter is the best available. Mine came with a CAI and I hated it, it was really loud. I sold it and put a stock unit back on and there was no noticable difference other than much quieter. I think the stock is good to 500hp.
Leave the stock setup in there. It is more than you need for what you have
Not sure on the diesels, but doing some data logging with my gasser truck, my IAT temps, are not much higher than ambient once on the freeway. The stock setup draws from the inner fender well. It does heat up at idle, but I think thats from the heat soak thru the plastics and what not. Once you get moving, it cools back down.
