Spontaneous leak from Bravo 1 transom assembly speedometer nipple >
Old 02-18-2017 | 03:22 AM
Default Spontaneous leak from Bravo 1 transom assembly speedometer nipple
The unused nipple, I have gps, on the engine compartment side literally just started flowing a steady stream of water into the bilge. Thoughts? Solutions?
FracBurner is offline
Old 02-19-2017 | 07:09 AM
Solutions?
Ayuh,.... Cap the nipple on the transom,......
Disconnect it outside the hull, 'n plug it,....
Bondo is offline
Old 02-19-2017 | 07:19 AM
I would remove the nipple and install a 1/8 NPT plug from the hardware store
[ATTACH=CONFIG]564907[/ATTACH]
Attached Thumbnails Spontaneous leak from Bravo 1 transom assembly speedometer nipple-speed.jpg
AllDodge is offline
Old 02-19-2017 | 07:45 AM
Thanks. I'll give it a go.
I'm just at a loss how it opened up. My undestanding is this connection is supposed to be fail safe. Meaning it doesn't allow flow when unused. The Bravo 1 HD assembly is maybe two years old. Here are some pics, if links work.
https://www.dropbox.com/s/z0n0wv0nkp...43515.jpg?dl=0
https://www.dropbox.com/s/zcymvqwdzk...sized.jpg?dl=0
Old 02-19-2017 | 07:57 AM
The fitting is below the water line when sitting. Appears to have a hole in the line coming from the fitting. If the hose on the outside is connected to the drive, then when running the pressure increases. I have mine plugged because its not used
AllDodge is offline
Old 02-19-2017 | 08:23 AM
Thanks again for the responses. Very helpful. Appears it should have been capped when the assembly was installed.
Old 02-19-2017 | 08:53 AM
Check the bilge for the fitting. My HP has a brass fitting that is capped off for GPS usage.
GLENAMY 242SS is offline
Old 02-23-2017 | 03:28 PM
Can't find anything in the bilge. Do you have a picture or possible even a link where I could get a cap for the nipple?
Having trouble getting the nipple off. It is recessed enough I can't get a wrench on it. Does anybody possibly know the size socket that would be needed to get the nipple off in order to install the pipe cap, as suggested above?
Old 02-23-2017 | 04:38 PM
5/16" PM me your email and I will send you a pic of the back of the gimble assembly.
Old 02-23-2017 | 04:44 PM
An 1/8 NPT should be 7/16
To find the pipe plug to seal it off, just go to any hardware store and ask for an 1/8 NPT brass pipe plug. Don't know where your at but here is one on ebay
http://www.ebay.com/itm/4pcs-1-8-inc...-/131435202358
[ATTACH=CONFIG]565026[/ATTACH]
Attached Thumbnails Spontaneous leak from Bravo 1 transom assembly speedometer nipple-s-l500.jpg
AllDodge is offline
