Hp500 intake on gen V 454? >
Old 03-02-2017 | 06:43 AM
Default Hp500 intake on gen V 454?
Will a hp 500 intake go on my gen v 454?
Darren Raker is offline
Old 03-02-2017 | 07:06 AM
SB
If rectangular port heads on the motor, yes.
SB is offline
Old 03-02-2017 | 07:08 AM
Stock peanut ports but I will be upgrading them also so just go with rectangle port heads?
Old 03-02-2017 | 07:14 AM
It will bolt to peanut port heads, just wont match the ports or be a good combination. I know of someone that did it, no improvement over the engine stock.
Mr Maine is offline
Old 03-02-2017 | 10:31 AM
SB
Pick intake for what heads you will use.
Don't pick heads over what intake you are going to use. :wink:
SB is offline
Old 03-02-2017 | 10:45 AM
It would work fine, if you are just wanting a manifold. Merc used the MPI Mag intake on the old (and kind of rare) 330 HP MPI, port mismatch and all. I don't think port matching IS AS critical on a dry flow manifold. While your motor will run forever stock, they don't have a good reputation when you start getting more power out of them...not that I think the HP manifold would add much.
liquidlounge is offline
Old 03-09-2017 | 01:07 PM
Ford 460 marine apps used the mongo port super cobra jet intake on basically the base model truck low comp long block with small port heads and a puny holley 650 carb. Shouldnt of worked well but did . aftermarket aluminum intakes on those showed little to no gain . Your set up will look cool , but wont gain anything without the dome pistons and bigger heads and cam that go with it
airjunky is offline
