Broken small part on top of raw water pump >
Old 03-05-2017 | 07:19 PM
Revspan's Avatar
Default Broken small part on top of raw water pump
Well, in the process of getting the raw water pump out, I inadvertently broke the little nipple on top of the raw water pump. It does not look like it is needed, but wanted to ask for some advice. What I am talking about is the part around the 11 o'clock position in this picture I found on the web. I hope it is not needed...as I reinstalled the pump, it THAT IS A PATA to say the least.
[ATTACH=CONFIG]565342[/ATTACH]
Revspan is offline
Old 03-05-2017 | 07:46 PM
Mbam's Avatar
Offshoreonly Advertiser
The little nipple is part of the quick drain feature where you use a bicycle type air pump to drain the sea water parts of the cooling system. If you have never or don't plan on using it you won't notice the difference.
Mbam is offline
Old 03-05-2017 | 08:14 PM
Revspan's Avatar
I didn't notice any hoses going to this part of the pump. Only the other two hoses that come from the pump on the heat exchanger....what you are referring to. They attach to the two fitting sitting on the same housing right below the part I broke.
I really do not use the drain feature, so that is really not an issue. Just checking to make sure I don't have some other issue.
Thanks...
Revspan is offline
Old 03-06-2017 | 06:07 AM
Mbam's Avatar
Actually the part that broke off is just a vent. Normally it would have a small hose running up the front of the engine that is just loose at the top. Don't worry about it.
Mbam is offline
Old 03-06-2017 | 06:09 AM
Revspan's Avatar
Thanks for the info!!
Revspan is offline
Old 03-06-2017 | 06:44 AM
everyones right ,have them run on the dyno,best money spent and piece of mind.i bought a set of motors a year ago from a guy in Missouri that was supposed to be 8-10 old.after getting them one had been taken apart and freshened up for some reason and of course the guy said he just had it "checked out".also said the outer was taken apart too but it wasn't.i had the other one taken back apart and found at some point something happened to it and had been fixed ,I hope right, fast forward to now.im getting everything ready on the boat to put them in so had them dynode,one makes about 50 hp less than he said and his dyno sheets say and one makes 140 hp less,this is the one that had been taken apart,we found the valve spring pressure is way too low on that engine so im hoping after changing that it will be up to where the frist engine is.long story short have them run if you can afford it!hell I cant even get in touch with the machine shop he said built them...have them run
blownzr1 is offline
Old 03-06-2017 | 06:50 AM
orry for this post^^^^ wrong thread cant seem to erase it
blownzr1 is offline
