Manually Degreed Cam Lobes >
Old 03-07-2017 | 09:33 AM
Rage's Avatar
Default Manually Degreed Cam Lobes
Looking for manually recorded cam lobe lift vs degrees rotation for any cam lobes. Any idea where to look for this?
Rage is offline
Old 03-07-2017 | 05:44 PM
i do not understand what you are asking.
mike tkach is offline
Old 03-07-2017 | 05:56 PM
SB
Try doing a search (Google or etc) for Cam Dr files, graphs, or etc
As there are a few machines out there, Cam Dr being one, Audie Cam Pro Plus being another, that will measure complete lobes.
SB is offline
Old 03-07-2017 | 06:21 PM
Grab a handful of Percs and your bound to come up with something. Ha
getrdunn is offline
Old 03-07-2017 | 06:24 PM
SB that is pretty cool though but I gotta stick with the old fashion poor mans engine block, degree wheel and dial indicator.
getrdunn is offline
Old 03-07-2017 | 07:01 PM
SB
A decent amt of engine shops have them....and a few cam companies use them after grinding a cam. I know Cam motion does...as an example.
SB is offline
Old 03-07-2017 | 09:13 PM
Rage's Avatar
Cam Dr files or similar from anywhere will never be provided to anyone outside the company that generated them. I been that route. Engine block, degree wheel and dial indicator readings are what I am after.
Rage is offline
Old 03-07-2017 | 09:36 PM
I'm not sure what you mean?
Typically, if you bring your cam to a shop that has a "cam doctor" machine, they simply put the cam on it, and measure the lobes at various points, and give you that data that has been recorded.
MILD THUNDER is offline
Old 03-07-2017 | 09:40 PM
SB
Hell, I'll do it then. LOL.
Here's one:
http://www.powermechanics.com/camdoctor.html
SB is offline
Old 03-07-2017 | 10:36 PM
Rage
Not sure exactly what you are looking for. If you plug your cam specs into your modeling software it should give you the profile at various lifts (mine does). Are you trying to validate what it is giving you? I'm sure it's not perfectly accurate because it's just estimating the intensity of the lobe. I just installed the cam in the 502 I'm building. I could profile it for you if you would like.
Bob
bobl is offline
