233 formula
Old 03-08-2017 | 12:46 PM
Default 233 formula
I am repowering a 1974 233 formula with a 454 magnum / bravo , does anyone know if or how much I can raise the X dimension ? thanks Murray
murray rideout is offline
Old 03-14-2017 | 12:48 PM
are you taking out a mercruiser pre alpha? or Volvo or OMC that have bigger transom cut-outs? are you planning or replacing the transom? or using the original cut-out?
dereknkathy is offline
Old 03-23-2017 | 08:01 AM
I am taking out a pre alpha and hoping to not have to re do the transom
Old 03-23-2017 | 10:08 AM
then your only option is installing the bravo where the MR was. raising the engine is off the table. raising the prop can be done with a shorter bravo or bravo variant, which is pricey. and you probably already have the drive, transom assy, etc to do the swap, so an extra 2k for a shortie is probably not in the budget...
Old 03-25-2017 | 06:58 AM
Murray, Was the pre Alpha motor setup a Chevy or Ford?
goin70 is offline
Old 03-26-2017 | 08:46 AM
don't think it makes a diff. same inner and outer transom assy. same hole same location.
Old 03-27-2017 | 12:31 PM
The old cutout should fit new Alpha, Alpha Gen2 or Bravo TAs. No problem..
Pismo10 is offline
