598 CI - what whipplecharger? >
Old 03-11-2017 | 07:46 PM
Tinkerer's Avatar
Default 598 CI - what whipplecharger?
I built my 598 to install an M4 Procharger. BUT I hate the way they look.
I am thinking on installing a Whipple charger instead.
This engine with the M4 produces 1400 HP. Is there a Whipple that will do 1200 HP?
8.6 to 1 compression. Holley sequential port EFI.
I was also thinking on going with the CNP ignition - is it worth it.
Tinkerer is offline
Old 03-11-2017 | 07:51 PM
5 liter
sutphen 30 is offline
Old 03-11-2017 | 08:26 PM
You have a death wish? Lol.
getrdunn is offline
Old 03-11-2017 | 08:30 PM
i have the 8.3L.my 588s are north of 1200 at 10 lbs boost,a very safe tuneup.5L are good to but bob teague said the 8.3 was better for my application.
mike tkach is offline
Old 03-11-2017 | 08:34 PM
I believe the 4.5L is one of the newer versions, with stronger parts, larger bearings, upgraded snout, etc. Capable of 1200+
I love prochargers though, but agree they are hard to rig and make look good.
My Baja had the intercoolers hidden under the rear bench, m3sc 500efi, really looked nice.
What about using a Whipple port injected intercooled manifold with a plenium on top! Will look SICK!
https://whipplesuperchargers.com/ind...product_id=223
https://www.google.com/search?q=holl...Vw8DZ8QgjYI7AM
http://www.kustomboltons.com/custom-...g-engines.html
Depending on room you could mount them reverse centered on the front, or on a twin engine mount them both on the outside or towards the center.
CNP is just badazz! Might as well why stop now! LOL!
offshorexcursion is offline
Old 03-11-2017 | 08:53 PM
Tinkerer's Avatar
I like that intake.
No death wish just insane.
Tinkerer is offline
Old 03-11-2017 | 09:05 PM
Originally Posted by Tinkerer
I like that intake.
Better rename your boat. "Just insane" I like it...
getrdunn is offline
Old 03-12-2017 | 10:46 AM
GPM
Just a thought, No one cares what the supercharger looks like if you reach the finish line first. Pay a model to ride around topless if you're worried about "looks"
GPM is offline
Old 03-12-2017 | 01:27 PM
My vote is for the 4.5 as well. I've used the 4.5, 5. and 8.3. The 4.5 will make that power no problem, it's super efficient, and lower profile. [ATTACH=CONFIG]565514[/ATTACH]
HaxbySpeed is offline
Old 03-12-2017 | 02:05 PM
Tinkerer's Avatar
When they are mounted on the front of the engine is that a reverse rotation Procharger.
Can the discharge pipe be rotated to blow downward?
Tinkerer is offline
