Source or cross reference for merc 502/500 fuel pump harness end >
Old 03-16-2017 | 04:32 PM
articfriends's Avatar
Default Source or cross reference for merc 502/500 fuel pump harness end
In middle of outfitting a efi motor on my dyno, im trying to find if anyone has ever cross referenced a gm harness end for fuel pump. Im setting dyno up and want to build a pigtail to trigger a relay or power a fuel pump WITHOUT butchering up mefi harnesses. I have a complete cool fuel pump i can cut wires off for this but really dont want to. Just spent 2 hrs at local auto parts store looking thru gm repair harness ends and found nothing.
Attached Thumbnails Source or cross reference for merc 502/500 fuel pump harness end-20170316_172140.jpg
articfriends is offline
Old 03-16-2017 | 04:33 PM
It would be the black end not in my fingers, says "ped 6" on it
Old 03-16-2017 | 05:10 PM
Kefurr's Avatar
Take a look here
https://www.acdelcotechconnect.com/p...tails-catalog/
Kefurr is offline
Old 03-16-2017 | 05:12 PM
bck's Avatar
bck
Charter Member#568
Try Metri Pack 280 for that style connector. Try an oem # 15300002 if needed. But just the 280 series should take you to what you need.
Straight bottoms and flat decks
bck is offline
Old 03-20-2017 | 03:20 PM
Definitely looks like 280 plug
whiskeytango is offline
Old 03-20-2017 | 03:30 PM
I can make you up a pigtail if you need it. Let me know.
Old 03-20-2017 | 06:35 PM
I ordered a male/female end offthe info given by bck, should be here tommorrow. when i search it on ebay from the 153 number some show two round male prongs in connector, some show the flat similar to what im looking for, we'll see when it shows up!
Old 03-20-2017 | 06:42 PM
bck's Avatar
bck
Charter Member#568
As long as it's a metri pack 280 I think you'll be good. If you ordered male and female then worst case is you have to replace both and it'll work, right?
bck is offline
