J tubes
Old 03-20-2017 | 05:42 PM
F-2 Speedy's Avatar
Default J tubes
any issues replacing them on a holley
F-2 Speedy is offline
Old 03-20-2017 | 06:06 PM
nope,they come out pretty easy.
mike tkach is offline
Old 03-20-2017 | 06:14 PM
vintage chromoly's Avatar
Don't need them
vintage chromoly is offline
Old 03-20-2017 | 06:17 PM
F-2 Speedy's Avatar
Its my understanding you do ^^^^ in a marine environment.
Patients though. I use a little dowel or punch on the standard tubes and slip in so when you grip and turn you don't crimp the tube. Also reinstalling new ones I like to use a little blue loctite just to make sure they don't end up spitting out an exhaust valve or worse yet transferring from one bank to another. But like mike said they typically come out with a little twist and pull action.
getrdunn is offline
Old 03-20-2017 | 06:19 PM
Nope.
Not required
Old 03-20-2017 | 06:22 PM
F-2 Speedy's Avatar
I have one on each carb that has a small crack, so for 30 bucks its piece of mind...........thanks guys
Old 03-20-2017 | 07:18 PM
are you sure they are cracked,most have a slit or hole in them facing the carb in the middle of the bend.
Old 03-20-2017 | 07:22 PM
F-2 Speedy's Avatar
ya Mike, its cracked up the side in the hole area, like it was pried up to straighten it
Old 03-20-2017 | 07:26 PM
I bought an HP750 and a HP1000 cfm from AED, they turned the tubes 180 degrees with the small side facing the middle. They said the coast guard approved that setup.
Baja8808 is offline
