Lifter madness >
Lifter madness
Lifter madness
Old 03-21-2017 | 09:40 PM
Default Lifter madness
Gen 6. Hyd roller... I am understanding I cant run the stock lifters with .610 lift, what do I need???there are 50 million different hyd roller lifters and its all rather confusing....
phragle is offline
Old 03-21-2017 | 09:41 PM
Anybody see anything that will work??
https://www.walmart.com/search/?query=rollerlifters
phragle is offline
Old 03-21-2017 | 09:48 PM
SB
What Gen block Phragle, and if a 6 like the cam, do you have the retainer/dogbones/ and spider ?
SB is offline
Old 03-21-2017 | 09:49 PM
Its a gen 6. I dont have the dogbones/spiders but I can get them ...
phragle is offline
Old 03-22-2017 | 06:13 AM
I went with the johnsons. Some still use the morels. The cranes were also recommended by a very good builder. I'd say pick one of those 3. The morels used to be the best but there has been a lot of complaints about them lately. This ruined my brain trying to pick a set. The johnsons have a .700 wheel as do the cranes. Which will cost you roughly 1.5-2 on duration. The morels are a .750 wheel which is the wheel most cams are specd with.
I bought mine from eddie young. He did very well on the price. Good luck in your search.
Crude Intentions is offline
Old 03-22-2017 | 06:56 AM
working on the same issue now as my sons boat has a failed what is supposed to be morels, johnsons are what I have heard the best thing about, they have a lube hole that oils the roller that most others don't but following this as well. I did run std GM setup with HP500 carb cam for years with no issues for what thats worth
ezstriper is offline
Old 03-22-2017 | 07:06 AM
There are 2 models of the johnsons one has the axle oiling one doesn't. 2116bbr is the model that I went with and was recommended by Eddie. It doesn't have it to my knowledge. Ron sporl also recommended the same part number.
Old 03-22-2017 | 07:46 AM
F-2 Speedy's Avatar
Is that a stock height body, meaning no push rod length change
Edit: I just looked it up......+.300
F-2 Speedy is online now
Old 03-22-2017 | 07:54 AM
Yes +.300
Old 03-22-2017 | 09:41 AM
I have been running the stock gen 6 lifters on .625 lift for 4 years with no issues. 150# on the seat, a little over 400# open
snapmorgan is offline
