How do you change the fluid in a #6 drive >
Old 03-27-2017 | 01:38 PM
Default How do you change the fluid in a #6 drive
I have not had any luck searching for a service manual or any luck with info on how to change the drive fluid in a #6 drive. Any help or links would be greatly appreciated!!
myfast70 is offline
Old 03-27-2017 | 10:37 PM
SFOcean's Avatar
Charter Member #394
Might want to specify wet or dry sump. Dry sump has the swept back skeg.
SFOcean is offline
Old 03-27-2017 | 10:58 PM
My recent research has found the first early dry dumps were The old style skeg
Unlimited jd is offline
Old 03-28-2017 | 12:05 AM
https://www.google.com/#q=1075sci+2+cycle+oil&*
6th one down is a PDF that covers the drive also..
ICDEDPPL is offline
Old 03-28-2017 | 09:03 AM
Give the Mercury Marine factory in Fond du Lac, WI a call. Just order the maintenance and parts manuals for the drive. All the info is in them. They are cheap and will save you time trying to lookup part numbers. (920)929-5000
mike38scarab is offline
Old 03-28-2017 | 10:36 AM
If it s a dry sump #6 then you will need a special tool (91-847468T & 91-847418) to remove the nose cone and change the filter. The gear lube is pumped in through the bottom plug, just like a Bravo, but once it reaches the top hole you need to rotate the propshaft 80 times to fill the filter cavity. It doesn't matter which direction you turn it. Afterwards, re-check the fluid level and then put the plugs back in.
GF?
Got Freedom? is offline
