Skater shop dolly >
Skater shop dolly
Skater shop dolly
Old 03-29-2017 | 06:58 PM
Default Skater shop dolly
Have a couple skaters coming into my shop that I am redoing. Has anyone made a dolly with caster to move it around the shop easy without the trailer? Looking for some advice on square tube size and wall thickness. The first 2 hulls I am doing are a factory 21 twin and a factory 24 triple. Assuming I can make one dolly that will work with both tunnel sizes since they are very similar in specs.
Thanks!
lift2win is offline
Old 03-29-2017 | 07:14 PM
Tony/JD Byrider made some...
phragle is offline
Old 03-29-2017 | 08:13 PM
Thanks, I will reach out to him
lift2win is offline
Old 03-30-2017 | 08:44 AM
cougarman's Avatar
Thanks!
Ever look at Yardarm Dolly's ?
http://www.yardarm.com/
cougarman is offline
Old 03-30-2017 | 12:42 PM
I built one for a 21 Cougar as a tow-able dolly to my ramp (single axle setup). Used 2" X 3" X 11 gauge tube steel. Worked great. It would be fine for a 24 as well, maybe even a 28 if it was on 4 casters.
Taboma is offline
Old 03-30-2017 | 05:53 PM
I use a small 12" tire pontoon trailer with bunks
light,,,easy to maneuver and can tow it to the water
mostly for 28+ with a 24 here or there
johnmiffco is offline
