357 TRS to Bravo conversion. >
Old 04-01-2017 | 08:18 AM
Default 357 TRS to Bravo conversion.
My buddy and I are replacing the TRS drives with Bravos in his 89 357. Anyone know where to get layout dimensions and templates to properly place the new holes? Thanks
ph1971 is offline
Old 04-01-2017 | 08:41 AM
Audiofn's Avatar
Charter Member #232
I bet if you call Formula you will be able to get it all. You can probably also take the prop shaft height of the TRS and go about 1" or so higher and do the math backwards from there. You are going to have to re mount and align everything anyhow so put it what ever heigh you think is best. Leaving it deeper is going to help with drive life, higher can be faster but you don't want to go so high that it won't get out of the hole!
Put your best foot forward!
Audiofn is offline
Old 04-01-2017 | 09:00 PM
Good call on inquiring with Formula. Thanks.
ph1971 is offline
Old 04-01-2017 | 09:05 PM
You ARE re-doing the transom-right? TRS and bravo/alpha cutouts are completely different...
rer233 is offline
Old 04-01-2017 | 10:18 PM
Did they make a 357 with bravo drives? Thought the smallest was 420 trs
Mr Maine is offline
Old 04-02-2017 | 07:35 AM
Audiofn's Avatar
Charter Member #232
Not a smal project at all.
Audiofn is offline
Old 04-03-2017 | 05:32 AM
I have seen it done...and yes...to do it properly a transom re-work is required. Everything is different.
sprink58 is offline
Old 04-03-2017 | 12:11 PM
I replaced a kamma setup in a 357 with standoff boxes and bravo 1's. The standoff box covered the relatively small kamma hole and believe it or not my transom was not rotted (1986 357). The did install the bravo in the 1991 and 1992 357's so Formula will provide you with the "x" dimension. Remember, these are conservative on Formula's part. I raised my 3" vs. Formula recommendation as I was using the 12" standoff of the IMCO standoff box. The boat ran fantastic with the bravo/IMCO combo I installed. Good Luck.
38fountainecman is offline
Old 04-03-2017 | 05:32 PM
Yes it's new stringers, transom, refit to bravos and 502's. Complete redo and yes he is out of his mind. Thanks for any help you can provide on set up.
ph1971 is offline
Old 06-04-2017 | 06:07 PM
had a 1991 357 with bravo 1 drives
Inrecovery is offline
